Will a DVI cord work on a spectrum 375 as long as i had the machines switch set on the right voltage for the plug being used?
?? 4 Askandy
Good question.
The quickie answer is no because the Spectrum uses a 3 wire cord that uses the same wires for both 115 and 230 volt operation. The DVI cord uses seperate wires for each voltage setting. That's why there are more pin connections in the plugs styles available for the DVI cord.
Hope this helps
Andy
