TIG or MIG on Aluminum
  • TIG or MIG on Aluminum
    Another planning ahead question, semi-related to TIG. If I had a D200DX sitting next to me, and I needed to weld, say, 1/4" and up aluminum, I would want to MIG, right? That seems to be the consensus here. So, say I also had a MM251 (or PM255), do I have to use a spool gun for aluminum, or will either of those MIG's feed the aluminum correctly using the correct liner and rollers (and gas of course)? Am I right to think that the cheapest spool gun I can get for the MM251 is roughly $800? What is so special about spool guns that they cost so much?
    I am 99% set on a D200DX, but considering the price of a spool gun, maybe a D300DX would be better in the long run... I can live with slower, as this is for personal use in a garage (or large personal shop in the future). Most aluminum and or SS I may weld will need to be rather pretty as well...
    Thanks for any input ideas...
    Joshua
    Jolane:
    The purpose for a spoolgun is to feed softer wires a shorter distance to reduce birdsnesting. Mainly used for aluminum but I've done SS with mine to avoid changing over a 30# spool from the main unit. I would recommend the mm210 w/spoolmate3035 as a kit it comes all ready to rock and roll, dual cylinder rack,solonoids,regulators, everything for around $1800{I think, but I haven't priced it lately** this is the setup I own and Bang for the buck its the hands down winner. I also own a D200DX and love it, it is a soft subtle machine and the mm210 is more aggressive and kinda bold.
    I have welded well thicker than the spec's on the 210 allow and will tell you I get tired before it gets overworked. I believe you can save a few bucks and get the same setup I have and still get all you want and need. A while back I posted a picture of my rig its listed as {D200DX cart** do a search and you'll find it.
      Thank you pjseaman,
      I guess I have not really considered the MM210 much, due to the tapped voltage controls. Maybe I am disillusioned. The price is definitely better, but is the tapped voltage output a hinderance? Is the maximum output too low for what I want? I have read that the MM210 is easier to setup, but I kind of feel I want the extra power and adjustability. I currently have a tapped output 110V MIG, the Red HD3200. It works great for sheetmetal, but I find myself wanting a variable output at times. Maybe there is a huge difference here, but it seems like the tapped output means the output current is even less finely adjustable than what I have now.
      I will have to research this issue further. I have also used my dad's very large Red MIG, I forget which model, but it is a huge power supply with separate wire feeder, and probably weighs ~400#. I can set that machine up fairly well, so I think I have decent enough experience to get started with a MM251 (maybe not though).
      Thanks Again,
      Joshua
      I just don't want to regret buying a D200DX, wishing I had spent the "extra spool gun money" on the D300DX instead.
        If you are concernd with appearance stay with GTAW. Tig welding is slower than mig, but appearance makes up for it. A nice machine to look at is the Syncrowave 250DX; for a personal use you can get by without getting the watercooled version with helps out the $$$ considerably. I have a spool gun for my MM210 and I find that I just run a little short on the power supply at times.
