I know there are four different modes of mig welding: short circuit,spray-arc transfer, globular transfer, and pulsed-spray arc transfer. What determines the mode you're in? Is it the voltage and wire speed? Are most machines capable of doing each mode? Thanks, Bruce
Mig Question
Modes
Pulse for thin stuff (less heat input).
Spray is only for flat horizontal position. Won't work on out-of-position stuff.
Globular transfer = who cares (it's a mess because of all the spatter).
Short arc = everything else.Be cool,
Alex
FREEDOM ISN'T FREE
SUPPORT OUR TROOPS
Spray-arc requires higher voltages and currents and argon-rich shielding gas. Depending on welder power, 86/14, 90/10, and 98/2 will spray. Spray is usually used on thicker sections - 1/4" and up. Spray is the most commonly used industrial process due to the high deposition rate it achieves. You'd need a power source that can run ~26 volts at 180 - 200 amps to spray with 98/2, and higher voltages to spray with less argon in the mix.
Hank...from the Gadget Garage
Millermatic 210 w/3035, BWE
Handler 210 w/DP3035
TA185TSW
