Hyd tank
    When I was a kid on the farm we had an IH TD-9 dozer with a hydrolic tank leak.Several people tryed welding it with no success.Finally I baught a tip for the torches rated for 1/2" steel (can't remember the size) and successfully welded it.I attribute the success to the fact that the flame burned out all the impureitys befor the weld was made as oposed to blowing holes durring the weld.
    For what its worth; Pete
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
      I know you already have the right answers from the right guys. But i used to weld hyd tanks for dump trucks. They just need to be oil tight...Bob
        I was messing with some numbers and found that the tube you are using for your oil reservoir 4” x 6” x .250” wall thickness works out to a volume of exactly one gallon oil per foot of tube +or- actual i.d. Most log splitters have a reservoir with the capacity of at least 5 gallons hydraulic oil.
        That said, 5 gallons of oil would require 5 foot of tube which alone weighs over 78 lbs. Do you plan to use the tube for the actual splitting beam?
        Just curious.
          Hydraulic Tank
          I have made and repaired a few. I have both migged and tigged them and have found that where you stop and start is where you usually end up with a leak. I always pressure test them by hose clamping a old piece of inner tube with the valve stem over the filler neck and plugging the other openings and put about 3 psi of air into the tank,go around all welded areas with soapy water and look for leaks. If you find one grinded the spot and reweld.
            VBI thanks for the numbers. I was not sure how much it would hold. I am using an old beam from a forklift upright for the main beam and a 4" I beam for the axle. Then I was going to mount the hyd tank on the back of the I beam. I know it will be heavy just with the beam off of the forklift but I know I won't bend it to quick. It will also have a 14hp Briggs and the pump and hyd control is off of a 5,000 lb cap. forklift so it should split pretty good. I hope.
            I want to thank everyone for your ideas and help. This is going to be a fun project.
            Bob
            • #21
              Hydraulic Tank
              Sparky I have found that disposable Freon & Helium (for filling party balloons) bottles have good fluid capacity,light weight and when turn sideways make excellent fuel & hydraulic tanks. You can weld just about any fiitting or mounting bracket you need onto them.You can usually find them at the dump,landfill or your local air conditioner repair shop (Free)
