Originally posted by Slag
Question about welding table
I live 30 minutes outside of Philadelphia, the place I contacted was Hoover Steel www.hooversteel.comLincoln Precision TIG 375
Lincoln Power MIG 255
Lincoln Pro Cut 80
Miller Elite Red Flame
Welding the frame to the top will not warp it, hardly at all. I know machinists build everything micrometer flat...not needed with a welding table. I have a 1/2" x 60" x 30" with the legs welded to the top and no frame.
If you build a frame and don't mount the top you can flip it over and use both sides if you should need to fixture an assembly then have to do another repair job. My current table is 3/16" steel and it is welded down and it will be the last time I do that, the top is rough and marred from grinding and tacking marks but the bottom is flat and clean, Kinda stupid in hind sight!
Originally posted by pjseamanIf you build a frame and don't mount the top you can flip it over and use both sides if you should need to fixture an assembly then have to do another repair job. My current table is 3/16" steel and it is welded down and it will be the last time I do that, the top is rough and marred from grinding and tacking marks but the bottom is flat and clean, Kinda stupid in hind sight!
Great suggestion pjs!Dynasty 350DX
Dynasty 200DX TigRunner
MM 350P
MM Passport Plus
Spectrum 375 Extreme
08' Trailblazer 302
