For the entertainment of several...
I tried using a little bit of paint stripper on one corner of the back side of the black painted circuit board from my Miller Syncrowave 300 welder. Unfortunately the stripper did not have much effect on the black coating, but it did desolve the "clear coat" under the black paint. I was able to remove small sections of the clear coat and the black substance in tiny scales. However, I think that this may also remove the markings on the board and the color bands and such on the components. This particular stripper may also de-laminate the printed circuit board itself!
I think that the next logical step would be to find out if there are solvents especially formulated for removing "black conformal coatings". I remember learning that conformal coatings are used to protect circuit components on circuit boards in the Marine Corps years ago. However, we learned how to remove clear coating on component solder joints and circuit board runs. We never considered removing component masking coatings on a large scale.
We were also taught to clean the board very well and recoat the repair site with the same or simular coating.
Yours,
Thumb Clip Pull Pin.
Yours,
