Got my weld cart finished for MM185 and Dynasty 300DX.....
  • Got my weld cart finished for MM185 and Dynasty 300DX.....
    Finally got my cart finished that I started awhile back, I like how it turned out. Looks like it would be top heavy but it isn't. It carries it's weight really well.
    ______________
    MM-185
    Dynasty 300DX
    Thermal Arc Arcmaster 200
    Gary,
    Great set-up but why when the MM185 comes with a factory running gear would you take it off and join the two?? It just looks labor intensive if you want to take the mig off and do a job away from the garage.
    Wheat Stalker
    Millermatic 210
    Fisher CZ-5...CZ-3D..
    Trek 5500
    1966 Amphicar
      Right after I bought the 185 I bought a Lincoln square wave tig and it didn't have a cart with it, about 5 1/2 years ago. I built a cart for the Lincoln tig and mm185 so my stuff wouldn't be taking up space with two different carts. When I bought the Dynasty last month it also came with a cart but everything wouldn't fit into the old cart so I gave it to the guy that bought my Lincoln tig and went ahead and built this new cart. Yes it was time consuming but I made some changes to this cart that I like better than the old one. Hope that kinda answers your question, if I had a bigger shop I would probably have them seperated but I only have a 20X24 shop and space is very important. I made it so that the mm185 can come out of the cart fairly easy. It was only out of the old cart 2 times in the past 5 1/2 years that I have owned it.
      ______________
      MM-185
      Dynasty 300DX
        looks good
          Whats wrong with this picture?
          garyput, either you have your torch cables hooked up wrong or I do. I have attached a diagram for you to review.
            Thanks for pointing that out. Guess that's what instuction books are for huh. We're men, we don't need no stinking instructions.
            ______________
            MM-185
            Dynasty 300DX
              Cart looks good, PLEASE chain those bottles to the wall...Bob
                Nice work. What did you use for your rod tubes? Looks like you have caps for them too.
                Thanks
                  The rod tubes are 1 3/4" od tube, .125 wall and the caps are 2"od, .125 wall tube.
                  ______________
                  MM-185
                  Dynasty 300DX
                    Gary:
                    Nice cart, mine is similar only smaller. Here is the post, http://www.millermotorsports.com/mbo...ead.php?t=1934
                    Keep up the great work,
                      Originally posted by pjseaman
                      Gary:
                      Thanks!!
                      ______________
                      MM-185
                      Dynasty 300DX
                        The cart looks fine. I can tell you spent quality time designing exactly what works for you and your environment. Now you have room for another machine!
                          The last cart I had was very similar to this one and after using it for 5 1/2 years there was some things I wanted different and I made those changes when I built this cart. It's probably good that I don't have alot more room or I would probably have a few more pieces of equipment.
                          ______________
                          MM-185
                          Dynasty 300DX
                            tig cart
                            Nice cart...want to sell your old tig runner cart?? Let me know
                            [email protected]
                              [email protected]
                              Already sold it.
                              ______________
                              MM-185
                              Dynasty 300DX
