don`t know if this has been asked many times but.....i have a miller vantage machine.machine is set up for 035 wire,would like to use on 20 gauge steel bought 024 wire and tips.and help in the set up would be apprecated.using argon/co2. Bill
new guy
If this is something you are only going to use once, then maybe not. What happens is that with the big liner, the small wire will snake in the bigger liner causing feeding irregualities. If you are planning on using your .023 more often, then yes. You will have less headaches. Also, make sure you get the right drive rolls or the small wire will slip for sure.
Andy
