I just got a 180sd and I am trying to use it on some 304stainless. The filler I am using is 308/308L and my beads are dark black. Am I just rushing too much and using too many amps or what is up? I thought that the weld bead color should be a straw/honey color.
tig stainless?
Originally posted by DmonI just got a 180sd and I am trying to use it on some 304stainless. The filler I am using is 308/308L and my beads are dark black. Am I just rushing too much and using too many amps or what is up? I thought that the weld bead color should be a straw/honey color.Dynasty 350DX
Dynasty 200DX TigRunner
MM 350P
MM Passport Plus
Spectrum 375 Extreme
08' Trailblazer 302
Give us a little more info i.e. gas flow rate,amps,etc. Since I haven't seen your beads I am guessing to low on the cfm. Also,make sure you have NO leaks in the Argon feed line, as this can contaminate your beads. Hope this helps. Keep us posted on your progress.
Mike
MACH4
Ok, here is a little more info. 3/32 2% Thorieated electrode. I was using some gas lens/cups made by Radnor. They were reccomended to me at the purchase of the 180. The cup tapers to a small outlet. Claim less gas usage and more electrode protrusion. I had the Electrode out about an 1/8". My Argon flow was set to 19 cfh. I am not sure what the amps were, but the max was set to 95. Kind of hard to see when using the foot control. The material I was welding was about 14 to 16 gauge. I will try to post pic later. Thank you.
for the sheetmetal thicknesses that you are welding on, it definitely sounds like your running toi high of a setting. Try dropping the dial on the machine down to around 80 amps. This will give you a little finer control over the weld puddle. You want your weld color to turn out similar to this weld on 16 ga. 304L SS- see attachment.Attached Files
Ok I moved my amps down to 75max. Reduced my gas flow to 13. and changed out to a 1/16 electrode. I also used the stock cup that came with my torch. I went after it with slow and easy mentality in mind. The upper right one in the pic was a before the advice. Things are still blacker than they appear in the pics. Would it help to move to a thinner electrode and filler, so I could run less current? I had another person look at the amp guage on the machine and I averaged about 22 to 26 amps.Attached Files
For what you're doing right now, I d use a .050 filler as my first choice and a 1/16" as my second choice. For the lap joint picture that i posted, I used a 1/16" filler. Your gas flow is lower then what i generally use. generally i just keep the gas set to 20 CFH, even with a gas lens.
You are the master!! I will go right out and try 20. I was just out there trying from 6 to 13. The gas I should be using is straight Argon isn't it? Would it help with a little smaller electrode? I measured the ss and it turned out to be closer to 18 gauge.
