I just noticed that Miller catolog states that the Millermatic 251 comes with "ARGON MIX regulator/flow gauge". It also lists a CO2 regulator/ flow gauge in the list of OPTIONAL accessories!!!!!! WHAT GIVES??????????
Are you telling me that I'd have to go out and buy an ADDITIONAL regulator for a BRAND NEW welder because I generally run straight CO2?
It seems that most migs come (as they should) with regulators that are compatible with both CO2 and Argon blends!!!!!
Does anyone know for sure if this is just hype? I don't recall ever seeing "ARGON ONLY" stamped on anyone's gauges. What could possibly be the difference?
It seems this MM 251 I'm in process of buying is becoming less and less of a bargain the more I re-check it!!
Any help appreciated, thanks!
