Hello all, I just got some samples from diamond ground. Tri-mix 30deg, .020 flat. I was sold on zirc-w for ac aluminum. However, I just did some 3/8" T joint 6061-T6 with there Tri-mix electrode and it worked great. Just wondered if anybody has used this type of electrode and what their opinion of it is?
Diamond ground products
Rob,
I have used the Diamond Ground tri-mix. My samples were a high polish finish sharpened to a point with a slight flat. They work well on DC SS GTAW where arc wander can be a problem. They are also great for AC TIG on aluminum with the Dynasty inverters. I have no experience with this tungsten alloy on a Syncrowave.
Everything I have seen, read, and done indicates zirconiated tungsten has all the qualities desired for AC welding with a standard squarewave machine. With the inverters I am still testing the tri-mix and the 2% lanthanated on AC and DC. I think I prefer the 2% lanthanted for AC and perhaps lean slightly toward the tri-mix alloy for SS-maybe.
Originally posted by rb455hoWhat is a good price for the P-2? Jim @ diamond grind quoted $625.00.Dynasty 350DX
Dynasty 200DX TigRunner
MM 350P
MM Passport Plus
Spectrum 375 Extreme
08' Trailblazer 302
Rob,
Jim has quoted you an excellent price. That is close to what I paid. The going rate is $700 as Kevin at KB said. I have a PII and really like. However, I don't use much precision ground tungsten larger than 3/32" with my Dynasty 300. This is the largest diameter the PII is made to grind. Kevin has a good point about looking toward the Piranha III with your Syncrowave. It is will grind up to 3/16" tungsten electrodes. My guess is you are using a lot of 1/8" and 5/32" tungsten with your new Sync 350. The Piranha
HAWK, let me retract my success with the TRi-mix. The first weld I did with it with a sharpened point seemed fine. Today once it balled up more the arc quality deterioated so I went back to Zir-W and you are right it is the best for the XFMR machines. In diamond grounds defense I am sure that the tri-mix works great for DC.
Rob,
The tri-mix is a great alloy for AC and DC with inverter engine machines like the Dynasty series. For the Syncrowaves I personally like the 2% lanthanated for DC and the zirconiated for AC. You only have to stock 2 tungsten alloys and they will do it all!
