TIG do you push or pull
  • TIG do you push or pull
    Hi once again, been pondering over this subject for a while, when tig welding do you push or pull the torch?
    You push tig.
      Any reason why you cant pull? since i tired it both ways the beads still came out nice.
        same as MIG
        would push or pull efect it the same as in MIG.
        thanks for the help
          Push is the only way I have ever done it. If you are pulling you would be adding the filler to the back of the puddle if you kept the same torch angle. I will mess around with that tommorow and let you know.
            pull it or push it.........**** what ever floats yer boat !
            dawg
              it seems every body dose it whitchever way works best for them kinda a go left ot right thing.
              not that it seems to matter but the book said push if fusing without filler.pull if adding filler.
              so the best way to do it is what ever way works best for you
              thanks for the help
                It would be pretty tricky doing vertical up. I have never pulled always pushed. I worked with a couple of guys that did vertical down on aluminum adding filler to the back of the puddle "I guess that would be pulling" They could never add enough filler and many times had the welds crack. You could never get them to admit that vertical up was the better way to go. Scott
                  I was taught to push, and it works so why mess with a good thing. I believe in kis{keep it simple} lets not re-invent the wheel.
                  Peace,
                    ****, I thought it was KISS (Keep It Simple, Stupid) I guess everyone was trying to tell me something?
                      Really, a push angle is best as when you push, the impurities are blown AWAY from the welded deposit. When you drag, especially with Aluminum, you are going to put all the cleaned oxides back onto the molten weld puddle and contaminate your weld. 5 deg - 15 deg push angle is used by most. Now I have used a back swirl technique sometimes with anodized aluminum. For the most part, even verticle up, push with tig.
                      Andy
                        That's a good point, ANDY: When you drag you are blowing everything that's been atomized by the process back over the puddle. When you push, most of those things will be blown away from the puddle because most of them are generated at the leading edge.
