Tungsten grinder
  • Tungsten grinder
    Why would a home shop guy with a DX 200 need a grinder, when a "tungsten only wheel "has been the norm for years?
    Seems that $200.00 could buy a tube bender or notcher???
    http://www.millermotorsports.com/mbo...ead.php?t=2009
    -Tanner
      Hmm. Interesting point. I suppose one might also wonder why a home shop guy might NEED (and spend a minimum of $2200) a 200DX.
      Dynasty 350DX
      Dynasty 200DX TigRunner
      MM 350P
      MM Passport Plus
      Spectrum 375 Extreme
      08' Trailblazer 302
        I don't think you do.
          KB Fabrications
          owww oowww
          i can anser that 1.
          power ishues is why i need the dyn200DX. a syncro180 would work but i cant feed it the needed 60amp's the dynasty will give me 200Amps with only a 30amp draw. i would love to put the extra $1000.00 diferance into a few cool tools but i have to go dynasty for power reasons.
          that being said i'm shoure the dyn200 will meet all my needs and i should not out grow it.
          thanks for the help
            owww oowww
            i can anser that 1.
            Fun,
            I know that is your case. I was mostly speaking to my perception of silliness in GWB's original post. It seems silly to me that a home shop guy that could afford to spend more than $2200 to get his welder and set ups would worry about spending $200 on a Sharpie tungsten grinder.
            Dynasty 350DX
            MM 350P
            MM Passport Plus
            08' Trailblazer 302
              owww
              i get it.
              my only real concern is weather it is realy that important to have the tip just right? it seems that close is good enough so getting a tung. grinding setup is realy just about saving time where time is $$$$$$$ so for a home shop it realy isent needed.
              that seems to be the general concensis as i understand it.
              thanks for the help
                I walk through an electronics store and wonder why anyone would WANT to spend 14000 dollars on a television....is it up to me to decide if they really NEED it...Nope. It's important to evaluate want vs need as an individual and not worry about the other guys. If I had to explain a NEED for all the junk in my shop then I'd be in deep trouble!
                Just my passing thought as I read this.......JEFF
                200DX 350P 625 Plasma & other stuff I forgot
                  Well said Jeff.
                  Dynasty 350DX
                  MM 350P
                  MM Passport Plus
                  08' Trailblazer 302
                    Here are four nice unit to consider;
                    WIG 10/175
                    The WIG 10/175 is a bench mounted Tungsten Electrode Grinder which can be used to grind and cut to length tungsten electrodes. The WIG 10/175 use a collet to clamp the electrode, this collet is then located in a holder and the collet is then rotated as the tungsten is introduced to the grinding wheel via a precision slide system. The WIG 10/175 us a bonded diamond impregnated grinding wheel gives exceptional life.
                    The Tig Point
                    The Sharp Shooter
                    The Sharp Shooter uses an innovative tungsten grinding system to provide accuracy and safety in a compact, yet heavy-duty unit. Its unique design reduces the skill required to allow for easy grinding, flatting, and cutting in an enclosed work area. Vacuum system options are available with HEPA filters in a quality work cabinet.
                    Turbo-4 Tungsten Grinder
                    Turbo-4 Tungsten Grinder is a capable, economical tungsten grinder. It allows for grinding and flatting of tungsten electrodes. Its enclosed work area protects fingers from accidents, lungs from harmful dust, and eyes from sparks
                    If You have to ask the Cost , they are not for You.
                    "Equipment Should Never be an Excuse for Poor Performance. If You are Going to be a Professional, You Get the Correct Equipment, then the Only Excuse is Your Ability to Perform." â„¢
                      expanding availability
                      it would seen thet the only true need is;
                      to know how inportant a perfect grind is.
                      that being said most people dont need a perfect grind, some verry specilized welds will but most wont.
                      i think like the plasma cutters, the tung. grinders are becoming more populare due to availability and price. i dont need a plasma cutter especily when you concider i have an O/A torch with cut and weld tips, yet i do have a plasma cutter. seems the tung. grinder falls in the same mold. and now that the sharpie is available for only $200.00 less than 10% of the welder caust i would tend to think it too will become more popular and indispencible.
                      although i have come to realize i will not need 1 i am shoure that i will save up in the hopes of some day having 1. why you ask. well mostly cuz it's out there.
                      thanks for the help
                        IMO it depends on whether you have a bench grinder or not. If you don't have a bench grinder why buy the bench grinder to sharpen tungsten when you have to dedicate one wheel just for that purpose because even a cheep bench grinder is about $50.
                          Fun,
                          __________________
                          So KB, sorry you thought this was a silly question...............
                          So do you cut wood in the same same shop you weld in???
                          Sorry that was silly....
                          A tig welder(weldor) that can't hand grind a tungsten, is like a machinist that can't grind a lathe tool by hand... .useless.... We don't do AEROSPEC in a home shop setting...........
                          A good investor spends his money wisely..............
                            You mean there is actually a market for these things? I never would have guessed it. Ha ha, just kidding.
                            I actually checked out the Turbo 4. It seems comparable to the PII in terms of size and functionality. Ultimately, I agree with HAWK when it comes to the Diamond Ground products. They remind me of Miller when it comes to product quality and customer service.
                            Dynasty 350DX
                            MM 350P
                            MM Passport Plus
                            08' Trailblazer 302
                              I've ground my tungs by hand on a bench grinder for years. Yes I do know how to do that. It works fine, absolutely. My business, however is growing by leaps and bounds. It's not because I can't do it, its because I would rather be welding than worrying about grinding my tungs and dealing with dressing a wheel, cleaning up the mess, etc, etc, etc.
                              My original point to your original post was, What does it matter whether these guys want to spend whatever on whatever? If a TG grinder is what you want, get it . If you don't want one, or feel the need, then by all means refrain.
                              A Miller Dynasty 200DX is an incredible machine technologically. If a home shop guy/gal is going to buy that kind of welder, then why would it be such a leap for him/her to get the latest technology in in tungsten grinders?
                              I did not mean to offend you and my response was probably a little sarcastic. It was meant to be sarcastic but not to offend you. I apologize.
                              Dynasty 350DX
                              MM 350P
                              MM Passport Plus
                              08' Trailblazer 302
