How about some actual needs. What type welder do you have and what input power requirements does it have? Some inverters are rather forgiving on input voltage and phase while transformer units are hard core about the power required.
I doubt you will find a residential area with 208 volts. You should have a minimum of 220VAC entering the supply panel. The best option is to find your machines power requirements(we can help you with that) and have a qualified electrician wire your machine.
3-wire edison
single phase meaning 2- 120volt to ground or 240 VAC between them. There is no other configuration regarding residences. Depending on who you talk to some people still say 110 and 220, motor people use 115 and 230, but the effective (RMS value) is 120 and 240 single phase. The only reason you would have lower would be to the I ^2 *R losses from excessive current draw. This lowers the voltage because of the power lossess in the wire. Believe it or not copper and aluminum wire does have resistance. I do not know if this helps but hopefully.
most residential power will vary from 220 - 240 volts. If you have only 180V, you have other problems. Most welders we make have at least a +/- 10% power tolerance and you may not need to do anything. Some also have primary power links you need to set to get the unit set to the power supply you have.
Folks your age don't know a lot about electical services, as a rule. You can take it for granted that your house has an electrical service that supplies 240 volts of alternating current (AC) to the main service panel.
Do you have a welding machine? If you do, what does the plug on the end of the cord look like? Any receptacle in your garage that looks the same? If you can match 'em up, you'll be good to go. If not, we can help.
Hank
...from the Gadget Garage Millermatic 210 w/3035, BWE Handler 210 w/DP3035 TA185TSW
thanks for the help
sigpic feel free to shoot me an e-mail direct i have time to chat.[email protected] summer is here, plant a tree. if you don't have space or time to plant one sponsor some one else to plant one for you. a tree is an investment in our planet, help it out.
Perhaps if you called your power company they would send a representative out free of charge to make an on site assessment of your power situation, it could be that they need to install a bigger transformer on the pole.
