just wanted to know what everyone thinks about using c25 verses using straight co2
c25 or straight co2
Gas
I use CO2. I have tried the mix but for my work the CO2 does a better job. I do a lot of repair work ( field and shop) and fab work with new steel. I have found the CO2 is a lot more forgiving when the part you are repairing is not perfectly clean and the penetration is better.
Wayne
Co2
Originally posted by bigwelderjust wanted to know what everyone thinks about using c25 verses using straight co2
i have heard so much about different transfer methods but to me i just weld with .035 solid wire and straight co2 coming from a miller delta weld 300 set at 26 volts with the inductance control set at 23 wire speed around 75to weld or not to weld that is the question
I used CO2 with the MM135 because it gave the biggest bang with the lower power. It worked just fine. Many folks report spatter problems with it; I had none.
When I got the 210 last month, I picked up 80CF of C-25, since I had the POWER! Welds real nice, but the difference is more noticeable welding thicker stock when the power is up (e.g. 3/8"). There is virtually no spatter, and the weld bead is very clean looking.
So, I guess what I'm saying is that there's a place for each - kinda up to the weldor!
Hank...from the Gadget Garage
Millermatic 210 w/3035, BWE
Handler 210 w/DP3035
TA185TSW
I've only ever used C25. I'm paying close attention to this thread.
Bulldog5 Passport Pluses
2 MM 212's
MM 210
MM 251 MIA
MM 350 P w/Python
w/ tig runner
Trailblazer 302
12RC w/meters
Spectrum 1000
Spectrum 2050
2 Black BWEs
Joker BWE
Star & stripe BWE Digital
2 star & stripe xlix's
REAL TRUCKS RATTLE
CUMMINS BABY
I'll stand on the other side of the fence. I prefer the c25 {75% argon-25%CO2} It has less spatter and cleaner arc charactoristics. Although it has less penetration it runs so much cleaner it is worth it to me. If I had a machine that I needed to max the penetration totally out yes I would grab for CO2. I have access to machines with much higher capacities than my mm210 so if can't do it I can get to a machine that can.
Weldmup,
Huh? Spray can only be accomplished in an argon-rich atmosphere?
Bigwelder,
I agree to a point, but as long as I stayed inside the parameters of the MM135, there was no spatter to speak of. If I treid to go where no man has gone before, BAD juju!
TA185TSW
hankj,
As far as i've ever been told you can only spray transfer correctly with a mix of 90%ar and any combo of Co2 after that, i.e 90/10,92/8, 95/5 etc. I've never heard of being able to spray with straight CO2, so i'm with you as to shruggin my shoulders.
BCBC
Coolmate 3
MM210 w/3035 spoolgun
Cutmaster 101
LC1230 12" Metal Cutting Saw
