Hawk you answer is here!
  • Hawk you answer is here!
    Hawk
    It worked good. I think maybe more cleaning and move back to a pure argon (50he/50argon was kinda a experament) should solve some of the problems I am having. Plus its 3/4" sch 40 aluminum pipe hard to keep the torch in correct position. Kinda been looking for a smaller torch head. I use the 20 that came with the dynasty. Any sugestions?
    Also Hawk what you think about the CK worldwide turbosharp-3 I can get a demo model for $480 what you think?
    Gary
    Dry Creek Welding
    Dynasty 300DX Tigrunner
    Trailblazer 302
    Spectrum 2050
    suitcase 12RC
    Hawk
    What is so good about Sylvania Tungsten? I see it cost a bunch. Is the extra cost worth it?
    Gary
    Dry Creek Welding
    Trailblazer 302
    Spectrum 2050
    suitcase 12RC
      http://www.arc-zone.com/catalog/web_...=microtig.html
      This one might be small enough to do the inside of that tube.
      Joe
      [email protected]
        I saw that model on saturday at PRI really nice but low amperage and lower duty cycle, than the #20. Depends on your work, definently not the 3/4" Aluminum.
        Peace,
          Pjseaman its not 3/4 aluminum, its 3/4" aluminum sch 40 pipe.
          Wrench3047 I am not needing to weld the inside just the out side. I notch one end of the tube and to a T joint.
          Gary
          Dry Creek Welding
          Trailblazer 302
          Spectrum 2050
          suitcase 12RC
            Gary,
            Coming from a distributor, Sylvania is more expensive, but it's like with most things if you want a better product then you pay for it, i know Sylvania also makes Tungsten for Bestwelds Tungsten, but i only use Sylvania, as for a reason other then belief that it's better without any acutal proof, i have no idea.
            BC
            BC
            Coolmate 3
            MM210 w/3035 spoolgun
            Cutmaster 101
            LC1230 12" Metal Cutting Saw
              GaryM,
              The Sylvania tungsten is "suppossed" to have a better quality control than some other brands. For the present I find it does a good job and would hate to change to save a buck or two. There are other good tungsten alloy manufacturers out there and don't be afraid to try them. Once you have a brand you like, stick with it unless you have reason to change. The GTAW process is one of consistency. Eliminate variables and your trouble shooting becomes easier.
              The Turbo Sharp is a nice unit, but I would save a little extra for the Piranha II. It is a much heavier constructed unit with a very nice sharpening wheel with some interchangeable grit options.
