can some one please explain multi-passing? maby how it is done! thanx
Can someone Explain Multi-passing?
Originally posted by paulrbrown21 is abut the proper number needed for 1" fillet or groove.......Patience is needed!
Wow paul that seems like a lot what rod you doing that with 3/32"???
GaryDry Creek Welding
Dynasty 300DX Tigrunner
Trailblazer 302
Spectrum 2050
suitcase 12RC
d-dawg,
Multi-pass technique is required when the thickness of your weldment is greater than your welder's single pass rating. The sequence of beads is important, as well as allowing the weldment to cool between passes, usually to at least 500°.
Beads should be run in sequence - the root pass will be the first bead. Successive beads should be run from one side of the joint to the othet IN SEQUENCE - bead 3 next to bead 2, then bead 4 on top of bead 2, bead 5 next to 4, etc., for as many repetitions as necessary.
Hope that made sense. It would be best if you went to the book store and picked up a copy of "Welding Essentials". It has a lot of good info for a beginer.
Hank...from the Gadget Garage
Millermatic 210 w/3035, BWE
Handler 210 w/DP3035
TA185TSW
For out of Position welds, welders max capacity can be to great to control. those big bad rods don't like to go uphill and overhead....I find 1/8" to work well and for me are easier to control. Before I welded alot, I saw a piece of ships anchor chain that had been welded together, each link 220lbs,12"x30"x7', they said it took 24 hours nonstop welding, I did not believe them at the time, but after study and actual practice, I understood. The chain was 750' long, not easy to move about, they used 2 D11 Cat Doziers.More Spark Today Pleasesigpic
