I just got my Dynasty 300DX (used) the other day. Last night I was welding some aluminum and noticed the torch got pretty warm. I looked at the cooler and the little blue flow wheel wasn't turning. I checked coolant level and thought it looked low and guessed that to be my problem. I filled the coolant as the instructions say and turned the machine back on and it worked fine. I welded again tonight and again the torch got hot, I unhooked the blue line going into the machine and opened the fill cap and pointed the blue hose into the fill neck and turned on the machine. Coolant was coming out of the hose so I know it is getting back to the machine. I hooked it back up and the wheel still barely turned. After a few minutes the flow wheel took off and was spinning like crazy and it worked fine the rest of the night. I also noticed when the torch was hot after some welding, the blue coolant line was jumping around on the floor (I have a zipper cover on order).
To make a long story short, what would cause the flow wheel to stop turning and how much pressure should the cooler be pumping. Has anyone else had this trouble?
