Question is two fold, on experiences and opinions.
1.) have you welded aluminum well, without using a spoolgun on either the mm251 or mm350p? Any major draw backs to this? Costs compared to Spoolgun?
2.) Value of inductance or pulsing capability on Mig GMAW, with Welding on different metals, espec. 6061, and 308L, chromemoly(probably has to be tig'ed)?
Before the end of the year, I'm determined to make an investment in a 220 volt welder.
Unfortunately in the long run, I will need both a Mig and a Tig.
I will probably get a loan for $2k, and spend 1000-1500 up front $$$$. So 3000 +/- is my budget, (have to spend quite a bit on electrical service upgrades as well, which is leaving things really tight for me.
However, I think a good mig welder might be able to keep me going on projects for quite some time while I save for an Ac/dc tig machine.
I consider the mm251 to be my minimum amperage requirement for thicker stainless, especially spray transfer.
Since I won't have a Tig machine for a while longer. I'm wondering if the MM350P might be a better choice.
My questions is on the value of the inductance control, and the pulse ability.
Does pulse help on aluminum or stainless?
I've read in the Mig book, and seen on the door charts that different inductance is more beneficial for stainless steel. And different inductance ranges are shown for steel, and aluminum as well.
My goal of course is proper welds, also with good appearance (which will no doubt require much development on the operator side as well
) and schooling is in the plans.
Since I was thinking on spending in the 3000 range.
Linde has a sale on right now on MM251's for 1679.00 (I guess they get an additional 5% margin from Miller right now, until the end of the year)
The MM251, would end up around 2800 with spoolgun + tax out the door, I'm guessing. I'm going to have them get some quotes together for me....
However, if aluminum is doable without the spoolgun (which I guess I could get later, after the welder is paid off). I might be able to squeeze the MM350P into the budget for $3300 - ish.
Now that I think about this, it will be even more than that, since I would need a spare mig gun with liner for aluminum, and maybe different drive rolls?
So now this might be more like $3700.00 - 4000.00 ? Which may still be worth the extra current capacity, for stainless, and the added control over inductance.
Hmm, that has me wondering about cost of the mm251, w/ AL mig gun and liner + a dyn200dx.
$4450.00 ish maybe.... Sigh.
So I guess the only downside to going with the mm251 and dyn200dx, instead of an mm350p, is that I will not be able to weld anything over .2" thickness while still having control over inductance, or having a pulse option. I think I will be ok with this. I think 98% of the exotic metals I may have to weld will be 1/4" or thinner, mostly tubing. I may end up with projects on Aluminum, and Stainless that will be thicker, (AL cyl head repair, etc), hopefully inducance control wouldn't be absolutely necessary for thos instances.
Well thanks for your insight on these questions, anything else I should be considering here?
Thanks in advance,
Don
Thanks in advance,
Don
