MIG welding upside down? Tips??
  • MIG welding upside down? Tips??
    I am building a '69 chevy truck and I started boxing the frame. However my upside down welding skills are nearly none. Does anyone have any tips? Basically I'm laying on my back welding up. Thanks for any help possible.
    IBRAILN
    MM175
    "Live for Today. Yesterday is Gone and Tomorrow May Never Come" -unknown
    oh come on man ! do a stitch welding techneque.... start/stop start/stop
    thats why mig is so easy to use.... you have total control over the weld puddle....if you think mig is hard of position try tig !
    by the end of that job you will be a pro !
    d-
      Boy I wish I would have thought of that. Something so simple. Thanks for your info. I will definatley do that....
      About the TIG welding, I am just venturing into that. I found a TIG at my work that isn't used so I have been practicing with it.
      Thanks again
      IBRAILN
      MM175
        Dial in your machine as close as possible, heat/feed.
        Pay attention to your nozzle, it will load up with spatter very fast and you won't notice it except your welds will get lousy and sooner or later you will realize why.
        As mentioned your trigger is your friend, you can control the puddle with it.
          and wear a weld jacket.......
          Lincoln SP170T
          ESAB 875 Plasma
          Smith oxy set
          pulsed mig is next...
          Long Island Cummins Ram Owners Club
            As df5152 said welding jacket{ leather ones cost more but it is a great investment at around $50 my hide is worth it, isn't yours?
            Weld well, weld safe
              And if you are doing a lot, a hat under your hood works well also!
              Nick Bezates
              Bezates Fabrication
              2 Ranger 9's
              1 Champion 16(Hobart)
              Invertec V-205 TIG setup
              Powermig 255
              AC/DC 225 Stick
              Cutmaster 50
              Thermal Dynamics Stak Pak
                IBRAILN,
                When hand pulsing welds like that I prefer to crank up the heat and dial down the wire speed a bit with a hot gas to get into a short arc/spray arc cross over mode. This allows for maximim penetration on those short trigger bursts and makes a beatuiful stacked bead.
                  Originally posted by arcdawg
                  [snip}....if you think mig is hard of position try tig !{SNIP]
                  d-
                  5/32" 7018 SMAW upside down, that is hard......
                  Regards
                  "Equipment Should Never be an Excuse for Poor Performance. If You are Going to be a Professional, You Get the Correct Equipment, then the Only Excuse is Your Ability to Perform." â„¢
                    Now, now... I know you know better than that.
                    With MIG, you do not have the ability to put heat into the puddle without putting filler into it... that's a very big advantage of TIG...which gives you much more control over the puddle.
                      Good point Engloid.
                        There ya go again Engloid, aggravating me w/those beautiful welds. grin
                        One day I hope to tig only half as good, that is if my time doesn't run out. LOL
                        Back to your '69 Chevy Truck, Ibrailn, I presume your building a show truck, I'm afraid you will not be happy w/the looks of the boxing or the strength if your building a race truck. I would remove the cab and bed, strip the frame of appendages for ease of fab. I built a rotisserie to mount the frame w/the body, front and rear axles intact, initially just to weld the underside of the mini tubs of my '55 Chevy HT, afterwards to do a frame off.
                        I know everone does not have area such a project, which I commandeered out front room for a parts room, my bride is soooo understanding, LOL
                        Good luck on your project
                        L*S
                          Thanks
                          Thanks for all the great info. I couldn't get to the truck last night but I will for sure tonight.
                          I would love to have a rotisserie to flip the truck, however it just isn't an option. I did remove the bed though, making the rest of the work much easier. Thanks- IBRAILN
                          MM175
                            how about some pics?
                            Lincoln SP170T
                            ESAB 875 Plasma
                            Smith oxy set
                              When I grow up I want to be just like Engloid. Is 37 to early to start thinking about growing up, Naaaaaa. I'll never grow up, I like my toys too much!
                              Engloid very nice stuff!
