- Does anyone know what kind of tungsten comes from the factory with the 150 STL. The package doesn't seem to be marked. I'm anxious to avoid the radioactive ones? Of for that mater does the machine come with tungsten? Mine has a bunch of cups, but what I was figuring is tungsten is actualy quite a lot like copper in appearance. Is it just some kind of spacer?
- Is there a particular electrode that must be used with this machine, as with the Dynasty series?
- The TIG kit does not come with a pedal or handle mounted control. Is something of the kind highly recomended? This machine is DC, and can't be used with aluminum, where I suppose the need to start real hot, then back off is part of the territory for such a conductive metal. Is the same true with mild steel, and maybe some SS? Other TIG machines kits like the accutig, or 180 SD come with the pedal, but they do aluminum.
