uphill or downhill
  • uphill or downhill
    Going to weld a step notch in my frame is it better to weld uphill or downhill?
    Using a mm 175 w/ .030 wire.
    Jrock:
    There is 2 schools of thought here, I do both here is why, up hill will put more heat in and thus have more fusion although my uphill gets a bit ropey looking. Down hill will give a fine finish look, but with less penetration.
    This is where practice helps so much, you get a feel for your own abilities and what you like, get some scrap the same thickness and try it both ways if you get the penetration downhill it will look better!
    I am a believer in practice before the real job. I vary from day to day in my hand speed and weave so I may run hotter today and faster , then tomorrow slower and need to cool down the input.
    Weld well,
      pj is right although if this is going to be a load bearing or structural weld it should definately be uphill.
      Trailblazer 302g
      coolmate4
      hf-251d-1
      super s-32p
      you can never know enough
        Thanks guys. Gonna get some scrap 3/16 and practice.
          A lot depends on fitup too. If you want penetration downhill leave some gap to get the weld in to.
