Ive recently started to use my Mig set up recenly.
Ive got a XMT 304 CC/CV with the 22A feeder. I am useing a .035 e 70S wire flux cored. My CO2 argon mix is 75/25.
Ive played with the voltage setting and the gas setting but i am not getting as clean of a bead as i want and im am getting exccesive amount of slatter, plus the weld is covered with the flux but it is as if the flux does not get completely melted to form the sheilding that it needs? do I make sence? it is gray and flakey almost.
Should I be using the flux cored wire with the shielding gas should I not use the shielding gas with the flux cored and when welding on 3/8" plate steel and angle iron what should my setting be on the equiptment?
wire speed, Gas, Voltage?
any thoughts would be extremly helpfull.
Terence
Terence
