learning pulse
  • Blown S-10
    ok, let me try it this way.
    i have a bunch of .030"ish extrusions. it does take a good bead on the flats. but i can't butt the pieces, just blows holes, even on 30a and less. this sounds to me perfect for pulse. so what settings should i start with ?
  • fun4now
    put it in
    Blown S-10
    put the piece back in, hmmm, that sounds like a good idea. yes, its steel.
    anyone think there would be a problem with this ?
    Mike W
    Since the inside is threaded, can you put the inner piece back in,
    thats what i would do for shoure will also insure your iner threads are lined up properly and keep everything in its right place
  • bigwelder
    i think i got it mostly pretty clean. i did lay some beads on it, but have 2 places where the bead came out on the inside. i can clean these up though. i just don't want to make any more.
    atleast you know u got good penetration on the bead
  • Blown S-10
  • df5152
    it will also be difficult because is probably cast aluminum and I assume you have used oil in the grinder over the years. recently tried to weld a cast aluminum diff cover. It was cleaned real good but over time it must have absorbed gear oil because thats all you could smell when you tried to weld it...
  • Mike W
    Since the inside is threaded, can you put the inner piece back in, assuming it is steel? Welding aluminum is easier with a backing of some sort so you don't have to worry about it disappearing before your eyes.
  • Blown S-10
    here is a pic
  • Blown S-10
    started a topic learning pulse
    learning pulse
    i need to repair a tool. its a air angle grinder head. the threaded area split. i pushed it back together just fine. but laying a bead is difficult, its pretty thin in this area, with threads on the inside. i'm laying filler on the base, then plan to fill it to the edge, about 3 rows of bead. all i need is good fusion, but little penetration. its about .040ish in this area, thicker towards the base.
    i was thinking pulse would give me what i need. but i have no idea where to set the machine. any ideas ?
