I recently purchased a used Miller Spectrum 300 plasma cutter (manfuacture year 2000). It is clean and well maintained and everything works properly but it won't make a clean cut in material anywhere near its rated thickness of 5/16". Even in 1/8" mild steel, the plasma will not penetrate the full thickness of the material unless I turn the output to its maximum (27 amps) and use a really slow cutting speed (perhaps 4-6 ipm). But if I do that the plasma will penetrate through the full 1/8" thickness but there is so much dross on the sides and bottom of the cut that it looks like a sever cut not a clean straight cut. I've tried both with and without standoff, and I am keeping the torch perpendicular to the work (I'm sure I'm not gouge cutting).
This is a switchable 110v/220v machine, and I have it running on a 220v / 30amp curcuit (yes I checked the internal switch to make sure it's switched for 220v input). I put in a new electrode & drag tip, and checked that the airflow is not blocked. I'm supplying it with clean dry shop air through a 3/8" hose with an inline water separator. There has never been an inline oiler anywhere in the air supply, and there is no sign of sputtering or any other sign of contaminated air. I have the machine set to 60 psi as recommended in the manual, and the compressor is supplying more than enough air to keep a constant 60psi reading at the gauge on the machine.
Do I have to increase the air pressure when I cut thicker material? The manual says nothing about that even though there is a pressure adjustment knob on the machine. It seems to me that there is enough heat to create all that dross but not enough oomph to penetrate the material.
It must be something I'm doing wrong, but what?
Thanks for your guidance...
Dean (novice plasma user)
