Well went to the local welding shop and finally purchased the Dynasty 200DX that I have been longing for. I also ordered the contactor kit with the finger control at the same time. Hopefully it is in tomorrow so I can play on the weekend. I have some questions:
What tungsten should I be using, I have a chart from Miller website that says use Ceriated or lanthanated for an inverter type machine. What is the difference between then, like does one weld aluminum better and one steel & stainless better??
My friend also suggest I purchase a gas lense? Is this a good idea? Do I use the lense with aluminum, or with everything.
What determines the gas cup that I purchase, I see there are ones with large and small openings?
I already have TIG gloves, autodim helmet, and mild steel, 309 stainless rod, and 4043 aluminum rod. Anything else you can think that I will need to get started TIGGIN
