dirty cups
  • dumbass
    Arc-Zone.com : Page Not Found - Connectors, Cable, & Adapters MIG Guns, Feeders & Parts Plasma Arc Cutting Plasma Arc Welding Purge Gas Equipment Remote Amperage Controls TIG Torches & Accessories Tungsten Electrodes Tungsten Electrode Grinders Water Coolers, Coolant & Parts Gas Flowmeters, Heaters, Mixers Stick Electrode Holders Shop Tools & Storage Apparel, Helmets & PPE Oxy Fuel Cutting & Welding Ground & Work Clamps TIG Welding Filler Rod Close-Out Products Welding Machines & Upgrades Weld Tables JIG & Fixturing Tools Automation & Positioners
    10n47 is what comes in the torch package for 3/32 tungstens. Get a #6 and an 8 too. See what the difference is you may like one better than the other. A bigger opening slows the gas down more. Or get a gas lens too.
  • DEA
    Here is some good information to download.It may take a little while if not on a broadband internet
    DEA
  • Blown S-10
    the cup size is matched (or should be) to the tungston size. then there is the different shaped cups, to allow for different joint applications. or so this is the way i understand it. me = fng
  • stumpjumperpro
    Another newbie question, what do all the different size cups do?
  • Blown S-10
    thanx, thats what i thought. i'm going to get some more parts, and have aluminum only parts. it may help, may not. but won't cost much to try it.
    anyone want to fill me in on the part #'s for the parts ? i don't know what all those #'s mean . to make things easier, i have a Weldcraft WP17 w/#7 cup & 3/32. i want to get a 7 gas cup, lense, etc. some more standard cups, maybe some longer of that size ?
    and i was thinking i would be able to use a smaller size tungston/cup for smaller work, could i ? what do you recomend for thinner stuff, like .025-.050 ish ?
  • ASKANDY
    Yes,
    A dirty or contaminated cup will contaminate the weld especially in aluminum. Not as much with steel. The contaminants will draw off the sides of the cup. If you pushed a filler rod onto the tungsten and blew it apart bad, it will also contaminate the cup.
    A-
  • Blown S-10
    started a topic dirty cups
    dirty cups
    when would a cup be considered junk, or need to be cleaned ? can a dirty cup drop junk in the weld ? as long as there is nothing loose on it ?
    can a cup be cleaned ? how ?
