I just bought a new dynasty 200dx welder and am in the process of doing some welds on .2" aluminum c channel. i am looking for information on the settings i would use for fillet and lap welds on this material. for example balance, all pulse functions, and waveshape
dynasty 200dx settings
Stack O Dimes,
Try 180-200 amps since you are welding just over 3/16" on the thickness and you are correct on the rule of thumb. Inverters require a little less than the 1 amp / .001".
Try setting the balance between 68 and 75 for starters. If the cleaning area around the bead (the white perimeter) is more than 1/8" turn the balance higher. If it is nearly invisible, turn the balance lower. If your beads develop pin pricks, lower your balance. Around 110HZ on the frequency is fine. 250 HZ will be too tight of an arc for a fillet or lap unless you are using He or an Ar/He mix. No pulse for this one.
Blown S-10,
The higher the balance the more penetration and less cleaning. Too low of a balance (55% or lower) will typically concentrate too much heat on the tungsten and melt it down. It will also provide too much cleaning with a lack of penetration.
