Scenario: Using a Bobcat 225G in the yard, in damp grass. Will grounding to a ground rod reduce/ eliminate shock hazard or none of the above. Not only from the standpoint of welding, but receptacle use and internal faults.
Neutrals are bonded to the frame and the ground lug.
Also, will use of GFCI receptacles increase safety, ie. reduce or eliminate shock hazard or none of the above?
I'll throw this out and run like heck.....
moe1942
moe1942
