I've had this machine for about 15 years as I remember, never given me a single problem. Where I'm currently working I have to move it around to use it. Lately I've noticed that the pedal box is getting hot after I use it. It may have been that way for a while but since I didn't have to move it I didn't notice. Normal or problem a coming?
Secondly the water flow has been going downhill for a while, too many mickey mouse water cooling setups on my part. I flushed the lines with some Lime Away, didn't get much crap out of it. Blowing air thru the lines I noticed that the power/water line flows air better one way compared to the other. The other water line seems fine both ways. I've been running a motorcycle fuel pump as a pump (max 3psi) but the return line just shows a trickle of water. I tried using a little giant submersible pump also but the flow doesn't seem any better. I pulled apart the brass fittings but didn't see any corrosion buildup in them after the flush. Weldcraft specs call out a minimum of a quart a minute, this setup now is about 1/3 of that. Looks like I'm going to have to step up and spend the big bucks on a ProCon pump setup. When I hook up the garden hose to it, it seems to flow ok .
