Suspect- Dynasty 200 DX, one year old.
It welded fine before yesterday- No contact problems, no nothing. Would strike an arc with out a problem.
Yesterday, an electrician came and put a new socket on it for 220/240.
Now when pluged in this way, it will not strike an arc on aluminum for the life of it. It will sit there, and want to start exactly like a ground is off, or not in good contact.
But everything checks out right, everytyhing is just as it was 3 days ago when I welded with it set up on 110.
What gives? Once it strikes an arc, I can run a bead fine, but trying to tack something now is getting pretty rediculous.
One thing he said when he took my little 110 socket off the cord is that it was backwards. Now I know that I suck at wiring, but I followed the manual to the T, on what wire went where.
Anyone run into this before?
Thanks
Louis
Thanks
Louis
