Miller suitcase 8VS
    Thanks for all the feedback. This is stuff you won't get in the users manual.
    moe1942
      Hi Moe,
      I have been reading your posts with interest. I have a Bobcat 250NT and love the thing. I hooked a suitcase to it and it worked great the only thing that I don't like with this setup is that when I weld in the shop I have to listen to the Bobcat running. I wound up buying a MM210. Quite! The Bobcat runs the MM210 with no trouble. I have used it a bunch of times with flux cored wire. It is no way as portable as the suitcase but for me it works out well. Good luck.
      Bulldog
      5 Passport Pluses
      2 MM 212's
      MM 210
      MM 251 MIA
      MM 350 P w/Python
      w/ tig runner
      Trailblazer 302
      12RC w/meters
      Spectrum 1000
      Spectrum 2050
      2 Black BWEs
      Joker BWE
      Star & stripe BWE Digital
      2 star & stripe xlix's
      REAL TRUCKS RATTLE
      CUMMINS BABY
        Thanks for the input Bulldog,
        I don't know if the VS circuit in the MM175 will be affected by the Bobcats alternator output. I think the voltage produced is a bit different than commercial power. Also isn't there a difference in the 225NT's alternator vs the 225G. I don't think it is as clipped as the output on mine.
        Someone from Miller will weigh in for the benefit of all.
        Smoke rolling out of a welder scares me and I'm fearless. If I could go back I would have bought the 3045FC. 29 pounds vs 70+ for the MM175...Too smart, too late.
        Thanks again
        moe1942
          Moe
          Suitcases......very cool!
          I don't think you'd have trouble with the MM 175 and Bobus. I run my MM 135 all the time off a generator with no problems. Just can't max it out. I don't think the Bobus output would be any different. Esp, since the sales brochure for the 2001 225 NT shows a set up with the MM 185. If it wouldn't run it, they wouldn't reccomend it....I hope.
          FWIW, the 3045 fc needs a power source, while the MM 175 doesn't. Makes a difference in the shop if you don't like noise.
          Don
          '06 Trailblazer 302
          '06 12RC feeder
          Super S-32P feeder
          HH210 & DP3035 spool gun
          Esab Multimaster 260
          Esab Heliarc 252 AC/DC
            Thanks Don,
            You and all the others who replied have proven the worth of this site. I re-read the Bobcat owners manual yesterday and did not find a definitive answer to any of the questions I asked. When I have to assume I start asking questions.
            I hope all my questions and rambling has helped someone else too....
            moe1942
            • #21
              No problem, Moe.
              As much as you helped me with my Bobus, it's the least I can do. I may actually get a chance to work on mine today.
              Don
              '06 Trailblazer 302
              '06 12RC feeder
              Super S-32P feeder
              • #22
                The alternator power is fine for running the MM175. It actually is smoother than years past. The MM175 may run a liitle hotter as the Bobcat's Aux power voltage is usually a little high. If using an extension cord, make sure it is of proper heavy enough gauge.
                A-
                • #23
                  Thanks Andy,
                  I should have been more specific early on. The Bobcats rated voltage was my main concern. 256-264VAC looked a bit much for electronic circuitry. I'm wondering if lowering the no-load to maybe 250 would be a little easier on my MM175.
                  My limited knowledge of electronics says slightly lower would be better than super high. I'm a worry wart when it comes to high dollar equipment.
                  If Miller says the warranty on a MillerMatic is good when powered by a Bobcat at rated voltage that should wrap up this discussion...
                  moe1942
                  • #24
                    They have been tested with the power circuit as is and runs fine. No issue with warranty either. The higher voltage will drop under load a little. All should be fine.
                    A-
