I own a miller syncrowave 175 machine which is fairly new with very little use on it. I'm a weekend car enthusiest building street rods. Recently I noticed that I get an arc between the tig torch and the grounded metal if I inadvertantly touch the torch to the metal prior to depressing the foot control. I don't recall getting this before but I'm not sure. The small arc is un-nerving and not good for the eyes when you don't expect it. The machine is set to the tig position with the remote footpedal plugged in. It happens at any amperage setting. Has anyone experienced this and is it normal or is there a problem with the machine?
Syncrowave 175 problem?
Yours must be one of the older models. But offhand, it sounds like a miscalibration of the footpedal. I don't know how it adjusts, or exactly how you could test the pin-outs, but there must be a way to make sure the physical position of the pedal and the signal being supplied are in sync. Perhaps someone here or at Miller customer service has the labels for the footpedal pin-outs?
Dan Payne, check to see if you have gas coming out all the time, that means the foot pedal is on, I had this problem with my Synchro 250 after dropping the foot pedal, it had bent something inside, I just bent back the offending part and Voila...You do have the amperage and output set to remote? If output is set to machine, the torch would be hot .
As S10 said, he gets this off his mig [little tinyarc], I have noticed that on the Lincolns like he has and the really cheap chinese stuff.More Spark Today Pleasesigpic
