would i void any warrenty if i removed that ugly warning sticker on each side of the machine ?
also, what wax do you use to wax the machine
when tightening down the gas hose, there is NO way to get a wrench on the fitting on the machine. i have found that these fittings needs to be pretty tight to not leak. and being able to wrench only the dinse fitting, 1/2 of the connection, would put a lot of strain on the machine side fitting. what should i do ?
this same gas hose. its seems like it is much longer than it needs to be. is there a reason for this ? not an issue, just wondering.
the handle on top. it seems like it will scratch the paint in time. any ideas to prevent this ? i want my machine to look new for as long as possible.
when i get to building a cart for this. how can i secure it to the cart ?
why didn't it come with a dust cap for the remote connecter ?
and the red plug that goes in the gas port, screw in plugs would have been better.
thanx, jess
thanx, jess
