CP300 Pulser box...how do you use it?
  • CP300 Pulser box...how do you use it?
    Hi,
    James (fun4now) advised me to start a new thread, and so I am! hahaha...anyways, I have a maxstar 152 with snap start II hf build with it. The package came with this CP300 pulser box that I have NO clue on how to use it. People said that its mostly used on AC but my machine is only DC...does that mean that I cant use this? There are 4 knobs and 4 switches, and I already read the manual but still no clue on how to use it...I tried it once and all it did was made a sound while tigging like a "tic tic tic tic" but it wasent even creating a puddle...
    Any help would be appriciated on how to use this machine...of even tell me if its useful or not, and how it will help me..haha
    Thanks again for all the help, much appriciated..
    best regards,
    cleaver
    newbi welder
    Hey Cleaver, the PC-300 pulser is a very useful tool that can be used for DC or AC welding. However its most common usage is on DC for thinner material. You plug it into your remote connection on your maxstar, and plug your foot pedal into it. Also, you need to plug it into 120v. Try these settings with 1/8" steel
    Maxstar
    Main Amps 150
    PC300
    % on time 40
    1 hz
    % background current 40
    If the unit seem to pulse alot faster than 1 hz, then we need to reset the internal hi/lo freq switch
    good luck
      cleaver,
      On an earlier thread someone also mentioned it is a good training aid as to when to add filler material, I personally know it made my welds better looking, and someone also mentioned they always use a little pulse 15hz, 90% on 50% off? to stir up any contaminents and raise them to the surface. Bottom line, I love mine and would not want to be without it. Hope this helps, Paul,
      ps, as you are using on an Inverter machine, you can use the higher settings, I believe they go up to 300 pulses per second, I am not sure, because I use mine on a Synchrowave 250 and it can only go up to 20hz.
      More Spark Today Pleasesigpic
        V,some idea what you can achieve by pulsing, Paul
          cleaver, few more images.
            he he he
            told ya........
            some times it helps to ask 1 ? at a time
            thanks for the help
              hello,
              I will try those settings with I get the chance...thanks!
              I tried it a few days ago before I posted this thread, and it was doing the same thing again...I guess I dont know how to use it and thats why its screwy! hahaha..all it made is these little spots and it didnt even make a puddle...
              but ill try it again..and your right james! good recommendation for the new thread! hehehe...
              thanks again,
              cleaver
              newbi welder
                cleaver
                when you use the pulser you need to increase the amp's to make up for the off time.
                thanks for the help
                  Ahh....good point! Ill do that next time..
                  thanks again as always James!
                  regards,
                  cleaver
                  newbi welder
