ARCDAWGS TIG pic's
  • #31
    Got it now.
    The test wasn't designed to stress the joint at the same load as the metal tube should capable of handling. I thought that if the tubing should be able to withstand X amount of load, then the test would apply that load to check the weld. Does that make sense?
    If it is destructive testing, then of course it should be destroyed or the test itself failed
    I have also seen a lot of "blob" welds on the equipment we use at work, but I have noticed that there is always a strong physical joint thereby minimizing the load on the weld itself.
    Thanks for the info guys
