thanks for the help
sigpic feel free to shoot me an e-mail direct i have time to chat.[email protected] summer is here, plant a tree. if you don't have space or time to plant one sponsor some one else to plant one for you. a tree is an investment in our planet, help it out.
thanks for the help
i'm new at this so dont take it the rong way cuz i dont know and am asking noy telling
that being said
it would seem that you should need to be concerned with what efect your weld dose to the surounding metal.
ie if you weld too hot and cool to fast you would crack or atleast weeken the surounding metal making a week point so it wouldnt matter how strong your weld was if you just trashed the property's of the steel around it .
yes
no
maybee
thanks for the help
the reason why i wanted to post those pics is for feedback and for people to see my skill level
when i attendened reds class they had a c.m bend test......and what you do is you fishmouth or NOTCH a piece then tack it then weld it all the way around......
it took me a few times to get it between running to hot or too cold or what ever it was
know when you are done welding the c.m you weld in a threaded bung and you thread it into the hydrlic bender.....crank up the psi and if it goes past a certain point (i think 5000psi) you pass
the whole point of this rambling is that the metal it self broke not the weld
ummm i dont think that anserd my ???
i did'nt say yours was bad i get it that it will break eventionaly and i get that the weld should bee the strongest point
but was i right or rong about the heat thing?
ummm too much heat is bad right ? rong?
do you need to find a happy meadeum to inshure a good weld without getting too hot ?
or do you just have to make shoure it's not too cold to get good fusion?
sorry i think you just confused me even more LOL
thanks for the help
James,
You are right to be concerned. If the weld fails in the HAZ then it is a bad thing. That being said, maybe they were just trying to get the students to understand the strength of the actual weld.
At any rate, a weld failing in the HAZ would be considered unacceptable. If you were building a dune buggy frame (that you or a customer would ride in) you would not want a failure in a weld or your corresponding HAZ. If it does fail in the HAZ, the metal was either problematic to begin with or it wasn't welded properly.
Hope that helps.
Dynasty 350DX
Dynasty 200DX TigRunner
MM 350P
MM Passport Plus
Spectrum 375 Extreme
08' Trailblazer 302
Kevin,
That was my concern. It looked like a mountain bike or motorcycle top tube to a head tube style of joint. Failure in that area would be castaustrophic.
gregj66,
Looked like a bike type joint to me as well. Before starting my own business, I used to weld bikes for Co-Motion Cycles. I've probably welded over 2000 different frames. We did some unscientific testing and the tubes would always bend or buckle away from the weld, never separate in the HAZ like that.
Dynasty 350DX
MM 350P
MM Passport Plus
08' Trailblazer 302
