Tungsten size & amp chart per metal thickness
  • Tungsten size & amp chart per metal thickness
    Can some one tell me if there is a chart that tells what size tungsten and amperage setting should be used on a particular gage and kind of metal... and...are the amperages for a particular size thoriated tungsten safe to use on the same size ceriated and lanthanated tungstens.
    Also,
    on page 22 of my 180 SD's owners manual it says 2% 3/32 thoriated tungsten is good from 135-235 amps, would it be better for me to use 1/16 X 1 1/2% lanthanated or 1/16 ceriated tungsten to tig 1/8 steel on my 180SD.
    Thanks guys for any help
    Best $1.50 you'll ever spend. For the Tig Calculator that is. Check your local distributor, I always have some laying around in our showroom. If not order on-line....heck, order the set for $4.00, money well spent......Miller Calculators
      tig welders handbook. Millerwelds home page bottom right!
      Trailblazer 302g
      coolmate4
      hf-251d-1
      super s-32p
      you can never know enough
        thanks guys
