I unpacked and assembled my 300DX TIGRunner yesterday evening. I am very impressed with the craftmanship. Today I played with it a little and I think I did pretty good for a rookie. I used the ceriated tungsten first. Later switched to lanthanated and it made a huge improvement. Seemed like it was much harder to contaminate. I'm having trouble with back stuff floating up. I guess I need to clean my filler and workpiece better. Hawks advice to setup the pulser to get a rythm worked great. I have alot to learn on machine setup. I'm going to town tonite to get a diamond wheel for my Dremel to sharpen tungstens. Also going to get some aluminum to scratch on. All I had today was some old scrap stuff. Real dirty. I cut an old A/C dryer in half a welded it back together. It was full of oil and sludge and I couldnt really clean the inside real well. I didn't have any acetone either. It looked pretty good to me all things considered. The filler didn't want to mix with the puddle real good. Do I need a different kind when it does that? I was using 1/8 4043. It would just drop a big glob. I would run the torch up over the glob and it would seem to start mixing in OK until I stopped and restarted. What is the right way to stop? I would end up with a crater. I used the HF start. Should I be using touch start?
I decided to go ahead with the ArcOne hood. It wasnt the Eagle, it's a Vision. Looks pretty cool. I'm worried about one thing though. I see a green spot when I stop welding. I hope I haven't burned my eyes. I had it set on on 12 TIG (the highest setting). Is this normal?
