I am attempting to learn to weld aluminum without a spoolgun. I purchased a roll of 5356 .035 aluminum wire and a bottle of argon gas. I am running a .045 liner and tip. The feeding has not been a real problem. However, I am not having any success running a bead. I set the volts, wire speed and reversed the polarity on the machine according to the chart. I cleaned the material with a new wire brush. When I attempt to run a bead the wire justs sprays onto the material. There is absolutely no puddle and no penetration at all. The wire just burns back into the tip and blobs onto the material. any suggestions would be appreciated.
Aluminum w/mm251
Why would you reverse the polarity? I assume you're saying you went electrode negative. I'll have to admit I've not done a lot of Al welding, but I've never gone DCEN either. I would think that could be causing your burn-back. Another thought just occurred, what alloy is the base metal? A lot of Al alloys cannot be welded.
AlexBe cool,
Alex
FREEDOM ISN'T FREE
SUPPORT OUR TROOPS
Stanley don't bother looking for a puddle when using 5356, it just sprays in. If you try some 4043 you can really play around alot with it and it actually has a puddle. Have any pics you can post as I would like to see some aluminum welds from this machine. I have a old 200 amp linde that I use for aluminum and really like the power of the bigger machines. Scott
