Hello I was wanting some feedback on which filler metal to use on 1 5/8 x .083 wall 4130 pipe. I have heard two or three different wire choices from different fabrication and machine shops. They all claim their choice is the correct one. I do pipe welding on different grades of chrome pipe in the petroleum industry, these welds are stress relieved after completion. Do these 4130 welds need to be stress relieved? Is there a wire that will work and not require post weld stress? Thanks to everyone that will give input on this subject.
4130 rollcage welds "input needed"
in the machining industry every welded item needs to be stress relieved. I have never heard of any of the local racers stress relieving their cages. If you do use 70 or 80 it should be uncoated to prevent copper contamination. when I welded chromemoly rearends at moroso we never stress relieved and in my four years never got a returned product due to weld failure. At moroso we used uncoated er 70 s3 tig and mig (.035 mig)Trailblazer 302g
coolmate4
hf-251d-1
super s-32p
you can never know enough
straight from e.a.a
three tempratures to control in c.m. welding
PREHEAT
INTERPASS (WHILE WELDING)
AND POST HEAT (PROPANE TORCH)
filler metal......er-80s-d2 er70s-2 er70-6
if this is what the airplane guys are doing i think that i would follow suit
dawg
http://www.jwharris.com/welref/faq/ Cut and paste this and go to the bottom for yor answer right from the horses mouthTrailblazer 302g
coolmate4
hf-251d-1
super s-32p
Hi, I am wondering about Arcdawg's response as it pertains to relatively thin tubing. I would like to know the Motorsports school position on this kind of weld. The seminar that I recently attended was taught by Wyatt Swaim, EAA guru and instructor and Tig Depot owner. His take was room temp, weld with 70... and done. No pre or post heat. Comparing notes is the best thing about this forum as I am here as a hobbiest and am always open to new info! JEFF200DX 350P 625 Plasma & other stuff I forgot
jeff, i took my BEND TEST at lincoln electric (sorry andy) motorsports class....
thin wall tubing (forget the #s) but i was running at 70amps on a squarewave 255.... at room temp (thats the key here) like you stated 70*
it is nothced out and then i tacked it in 4 places then welded it no pre and no post heat.... put in the bender and cranked to 5800psi........
the guy i learned from (joe kousla) is good freinds w/ wyatt and is heavily involved in the e.a.a. and motorsports welding
when it comes to c.m. welding i much rather do the PRE heat on it cause when its a airplane frame or a drag car chasis ........i rather be safe then sorry
dawg
Thanks Dawg, I have heard too much do heat, don't heat that it is good to get some input. I know you went to the school (OK, I'm jealous) and I was curious as to their take on it. Thanks for writing, JEFF On an unrelated subject I am always surprised at Miller's lack of exposure in the motorsports world. I'm a drag car guy and Lincoln always maintains a presence at NHRA races as well as most large circle track series.....JEFF200DX 350P 625 Plasma & other stuff I forgot
needless to say the teachers at lincoln were not happy when i told them that i prefer a SYNCRO to any of there stuff *(shameless plug...now send me one)
i will take a syncro 250 w/ pulser unit or a dyna200 w/ watercooler
that can all be sent to arcdawgs house !!
dawg
