Here are some photos of a new wood burner and sandblaster i built, the burner is a cut down oil tank and the sandblaster was made from a 30 gallon LP tank. I called my LP dealer asked what an LP tank is pressure rated at and he told me a tank like mine was pressure tested at 275 psi.
I only need to sand blast very occasionally once or twice a year, and then I will only be running 90 lbs of air through it so I think I should be fine. I pressure tested it at 135 lbs for 20minutes without a hitch.
Any suggestions or comments negative or positive will be appreciated thanks.
http://photobucket.com/albums/v140/pre-ban/public/
