Look what I found
    klsm54
  • klsm54
    I am glad to hear the good report HAWK. The knock by many on the Hobart board was that the machine is a "Gimmick" machine. I have been selling welding equipment for many years now, and I can say that if one company is not prone to bringing out gimmick machines, it is Miller.
    I don't see this machine as replacing the MM210, or the MM135, but when there is a need for both, it certainly would be better than buying two machines. The adapter plugs and automatic linking are great ideas.
    I have not seen the list price yet, but I can see it as a great machine for the beginner who would normally buy a 135, knowing full well that he will upgrade when he gets his new garage , with 220 power, built. Why go through that buy, sell, buy again hassle. Just buy the DVI and be done with it.
    Also great for maintenence applications where the machine will be used on 220 in the shop, but may be used in areas that only have 110 power. Race teams are another great application. Most of these guys have 220 in the shop, but may want to take the machine to the track where they only have access to 110 volt power...And the list goes on.
    Time will tell, but I think it will be a good machine. Possibly a "Niche" machine, but hardly a gimmick.
  • HAWK
  • HAWK
    What HAWK Thinks about the DVI
    This machine is still a proto type machine in most areas of the United States. It has seen a limited released in a couple of areas. I have spent countless hours with the proto type version and can honestly say I love the machine. I really crackles on 120 VAC up to about 135 amps. The 240 VAC brings it into the 175 amp top end.
    The arc is soft and similar to the MM210. This machine makes clean crisp welds. It pushes .023" and .030" ER70 series wire very well on 120VAC. It will run .035" on 120VAC, there is no real need as the .030" really rocks!
    On 240VAC it is killer. It has a great short arc even with .035" wire and lays out a very clean spray arc with .030" wire and a 92%argon / 8%CO2 shielding gas. I have run the DVI a lot with the standard 75% argon / 25 % CO2 gas mix and it is a fantastic short arc unit.
    The plug swap out is great. It is quick and easy. That's about all there is to that.
    It is designed for those users working with up to 1/4" material. I don't mean welding 1/4" like a MM135 will. I mean rocking with it. I run a lot on 120VAC up to 3/16" material and hit the 220VAC for the 1/4" and spray arc mode.
    I have not been able to hurt this machine as hard as I am on equipment. It is a fantastic idea and works well. Sometimes it is great to plug up and weld as oppossed to setting up the ALT or XMT or even the Dynasty stations. There are times when plugging up and migging is what needs to be done. This machine falls somewhere between the MM135/175 and the MM210. I think it is a better machine than the 175 due to the transformer/rectifier bridge that allows for the dual voltage input. It does not have the guts of the 210 and was not designed that way. The 210 offers a higher top end with the dual gas valves and is out of the box ready to add a spoolgun. I see a possible option of adding a spoolgun, but would look toward the 210 if that is in your plans.
    I have to say since this machine has been in my test shop the ALT and other MIG units have become jealous as their MIG usage has been quite limited. I like this machine "o so much" it has become my right hand for numerous projects.
    If this piece of equipment is getting bad reviews it is for one of 2 reasons:
    The operator has not spent any time learning the machine
    or
    The operator doe not have much experience with MIG machines within this class.
    These are bold statements. I feel qualiied to make then as I have spent numerous months and countless pounds of wire/ CFH of shielding gas in various mixes welding with this unit. Anybody that say different just does not know what they are talking about. Strong words. Strong machine.
    If you are searching for a dual voltage MIG capable of good solid hot 1/4" welds in the short arc mode ; a good clean spray arc with appropriate shielding gas ; easy to use ; and shop portable, then this is your machine.
    I WILL HAVE ONE IN MY SHOP!
  • Paul Seaman
  • Paul Seaman
    If I were moving a wire feed from job to job this might be a good possibility but I still prefer the extra power of my mm210. Just a .02 worth.
    Peace,
  • scott
  • scott
    Did the negative feed from the hobart members, come from people who tried this machine ? scott
  • HAWK
  • HAWK
    Originally posted by arcdawg
    i wanna hear what hawk thinks ?????????
    arcdawg,
    Headed out for a meeting. I do have some input, but it will be later this evening. Hang tight-intersting stuff.
  • cope
  • cope
    Most of the feedback over at Hobart is negative, and while I think Miller will sell them, I kind of agree.
    Still, it doesn't matter what someone else thinks; if you want one its your money.
  • arcdawg
  • Tanner
  • Tanner
    Originally posted by Manny
    Just saw it over there as well, looks like a neat machine, know if I was looking for a 175 machine this would be it. Reading the literature/specs posted however, I'm not unhappy that I jumped past to the MM210.
    Manny
    PS: Tanner you're gonna have to change you signiture to "future DVI owner"
    Ya know, looking at it, for about $100 more, I can get a more powerful machine..
  • fun4now
  • fun4now
    sweet
    looks like just the ticket for a gerage hoby shop. wish it was out when i got my mm135 i would have got it insted. i am verry happy with my mm135 though it continues to amaze me every time i pick it up
  • Manny
  • Manny
    Manny
  • Tanner
  • Tanner
    started a topic Look what I found
    Look what I found
    Found this over at the hobart board. This is EXACTLY what I need in a welder. Absolutely perfect for me. My next purchase!
