on aluminum or steel or bolth ???
after you ground your tungsten did you make shoure it was smooth? did you grind in the direction of the tip?
if on aluminum did you put a small flat on the end of the tip?
if you ground on your bench grinder did you use a stone that is only for tungs.?
what setings are you on?
can you give us some more feedback?
hopfuly the anser to all above is yes
i understand that if you grind acrost the tungten it will cause that type of behaver
thanks for the help
sigpic feel free to shoot me an e-mail direct i have time to chat.[email protected] summer is here, plant a tree. if you don't have space or time to plant one sponsor some one else to plant one for you. a tree is an investment in our planet, help it out.
