Welding Table "Again"
    [ATTACH=CONFIG]n571586[/ATTACH] Here's my 2 cents for a welding table I've built 5 of these so far . I would say it's a good medium duty table that will safely hold around 3000 lbs. I use 1/2"x4'x8' plate for the top because you can clamp it flat to the the sub frame. Tried 5/8 plate it didn't pull flat that sucked. I got the casters for Grainger the part number is on the drawing I'll post.
      2 more pictures. Welded chain links on the end for holding purge bottles. Even full loaded down with parts these tables roll easy across the shop floor. Hope this is helpful.
