looking at buy a tig welder
  • looking at buy a tig welder
    I have use the dynasty models 200 and 300 and at first glance they will seem to do what i need, weld aluminum. I have a 170 amp mig welder no spool gun available. I want to be able to weld 1/4" AL when necessary most often i will be welding schedule 40 pipe in aluminum. will the 200 do this without a problem I dont want to buy to small a machine but dont have the $$$ to spend if i can get away cheap. also have much current do i need to operate the 300 I have a 50amp breaker for my welder and plasma machine now. I like the inverter technology and most often will be welding in residential areas less interference is desirable.
    Dan
    Lincoln SP170T
    ESAB 875 Plasma
    Smith oxy set
    pulsed mig is next...
    Long Island Cummins Ram Owners Club
    The 300 will fill the bill better for 1/4". Your 50 amp breaker will support the unit up to 200 amp. You need 60 some amps for 250 output. If you are going to be welding 1/4" often you should consider a water cooled torch and a coolmate.
    Others with more experience will fill in the real life details but the 300 would be my choice.
    Good Luck!
    Bob Sigmon
    Bob Sigmon
    ___________________
    Dynasty 200DX w/ Coolmate 3
    Miller Passport
    LMSW-52T Spot Welder
    A/O Setup with Meco Midget
    Miller Big Window Elite
    Quincy QT-5HD
      df5152,
      WELCOME TO THE FORUM
      SHORT AND SWEET!
      I use both machines. The 200 will cut you short on this application. It will do it, but won't like it! Get the 300DX TIG RUNNER PACKAGE. I push the max on the 300 with a 50 amp breaker. No warm wires. No claims or recommendations here on the wiring... Consult the owners manual. It can be downloaded:
        looks like the manual recomends a 100 amp breaker which i dont have any other choices?
        Lincoln SP170T
        ESAB 875 Plasma
        Smith oxy set
          You might check with an electrician knowledgable with welder installations. I think the 100 AMP circuit may be overkill in this instance. However, if you follow the advice of the manual and or a licensed electrician , you will have peace of mind in your wiring. It is better to do it right than burn the house down!
            AMEN, HAWK!
            Weld on,
            Alex
            Be cool,
            Alex
            FREEDOM ISN'T FREE
            SUPPORT OUR TROOPS
