I'm having trouble getting an arc again. This time nothing seems to fix it. To eliminate grounding as an issue, I'm trying to weld on a small piece of tube about 2" from my ground clamp. I've checked the cable connections. I resharpened the tungsten. No arc.
I'm using hf. With lift arc I can get an arc.
When I step on the pedal, the machine makes a noise but no arc. Is the hf dead?
