Hi,
Is their any advantage of using a larger diameter tungsten? I know a 1/16 tungsten is rated for a certain amps (say 100), while a 3/32 tungsten is rated for (say 180) I don't know the exact numbers. If I were to weld a piece of mild steel tubing, at 75 amps and both tungsten were sharpened to a pencil like point, would their be an advantage of using the larger tungsten. I guess the larger tungsten would stay cooler.I have had good luck using a 1/16 tungsten on my projects, welding 1 5/8 .134 wall mild steel tubing and 1" mild steel tubing. I seem to stay with the smaller tungsten on my steel projects and 3/32 on my aluminum projects. Any thoughts? Thanks Anthony
