my brother has a winter beeter that has a pipe to exost manafold problem he just wants closed. braizing i thought might work any ideals.
thank for the thoughts
thanks for the help
sigpic feel free to shoot me an e-mail direct i have time to chat.[email protected] summer is here, plant a tree. if you don't have space or time to plant one sponsor some one else to plant one for you. a tree is an investment in our planet, help it out.
Brazing prob would be the best and cheapest if it's just a beater. Make sure you grind all around the crack or area real good to solid shiny metal first. You can stick weld it with cast rod but it's expensive...Bob
fun4now , I have used 7018 rod with sucess on cast boat manifolds, just don't weld much at once, maybe 1" of bead, let cool and go again.I was always able to lay my hand within a couple of inchs with out getting burned. Paul
i have good luck using eutectic 2240 rods on cast iron.i welded a steel pipe to an exaust manofold on a farmall tracter.preheated the manofold,welded one half,moved to other side and welded other half.peened it a little,been on there 2 years with no trouble.i have also welded cast iron that i could not keep it from cracking ,no matter what i did,preheat,peened ,post heat,sometimes it just dont work.
