Structural Steel
  • Structural Steel
    Ok want to further my welding skill and have been doing a lot of stick welding and ran a 3/4" plate but weld off the procedures outlined for my stated performance standard. It took a lot of passes with 7018 to finish out the weld with 3/32 should have used 1/8 but did not have any.
    There is a picture posted of the weld when it was all done. The cover pass looks like crap to me but I have no idea what one should look like. I did a really good job of cleaning between each pass. The slag came off so nice. The set up at 110A looks to be about right. At least that is what I think.
    Please tell me what to do different.
    Gary
    Dry Creek Welding
    Dynasty 300DX Tigrunner
    Trailblazer 302
    Spectrum 2050
    suitcase 12RC
    Gary,what position was this weld done in? If it is flat then you could even use 5/32 rod to speed things a bit but 1/8 is okay to use aswell. What guide lines did follow? As far as the cap pass is I think you moved a bit fast on the weave just try to slow it down a bit. And remember the only position that you have to weave in is vertical if it is not vertical then you run overlapping stringer beads.
    Hope this helps.
      I went off WABO Washington Association of Building Officials. The weld was done in 1G or flat, it was the frist one ever.
      So you are saying on my cap i could have just made a couple passes a litte hotter to get a nice flat weld and that would have be ok?
      Before any more practicing is done i am going to get some 1/8 and 5/32 rod. I think on the bigger rod that my synco 180 does not have enough of a duty cycle to get anything done. Should have my dynasty 300dx in 2 weeks. Then I can run bigger rod quite well.
      Gary
      Dry Creek Welding
      Trailblazer 302
      Spectrum 2050
      suitcase 12RC
        If the code dose not require a weave for the cap then I would run 3-4 overlapping stringers. And for 3/4 plate the heavier rod should work better. That weave was really wide for 3/32 rod. I to have not run 5/32 rod yet on my 180sd around here I can just about everything with 3/32 and 1/8 6010 and 7018.
        Keep on trying and I am sure that you will get it.
